question about brembo brakes..
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
logicmobile
Car: infiniti g35 sedan
I have 2003 g sedan with non brembo brakes , and have 17 inch oem 5 blades rims, if i wanted to upgrade my brakes to brembo,
1.what do i need to make it fit to my car? 2.Does it need a caliper brackets in order to get the rotor clearance?3. do i have to upgrade rims , like rotor will not hit my rims?
thank you in advance ...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
You need a set of brembo calipers from a g35 or 350z. You also need rotors from either vehicle & brake pads. There is no rotor as the brembo brakes aren't a floating caliper. They bolt directly in place of your oem brakes. You can run the 17" wheel, but you will need to run a 15mm spacer to push the wheels away from the caliper. You can get a set of 15mm bolt on spacers on ebay for $88 shipped. I have a set and they fit perfect, they are even hubcentric with a centering ring.
logicmobile
thank you , thats clears everything,
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
