question about brakes
dj56x
Car: 1989 nissan 240sx (sold), 2001 mustang cobra(sold), 2000 eclipse GT, 1993 240sx(sold), 1990 240sx
Ok so i finished the engine rebuild and just discovered I have no brakes. I've already bled the brakes and still am getting air in the system, besides there could be a hole in the line what else could possibly be wrong?
costa_rican13
Car: 1993 s13 coupe
the master brake cylinder could be bad. the cap on it could be too. the little rod at the top that screw thread that controls the in and out motion of brake master cylinder could be threaded on too short or to long for the pedal. also possible hole in teh lines like you said previously.
Frankenfourty
Car: 1989 240sx CA18DET
Bleed your master cylinder maybe.
Edit: Didn't see the post above me.
dj56x
when I push the brake pedal I can hear the master cylinder making like a juicy(not sure if that the right word to use) sounds
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Check hoses, lines, and unions, then bleed and bleed.
Driver read, passenger rear, passenger front, drivers front.
costa_rican13
Car: 1993 s13 coupe
dj56x wrote:when I push the brake pedal I can hear the master cylinder making like a juicy(not sure if that the right word to use) sounds
seems like maybe the little rubber seal is bad. so yea you need a new master cylinder then follw the bleeding method as stated above ^^
dj56x
OutToWinPAHC wrote:Check hoses, lines, and unions, then bleed and bleed.
you mean passenger rear, driver rear, passenger front, drivers front...
Hijacker
Car: '92 240sx Convertible
'94 F-150
It's driver rear first. That's the brake with the longest plumbing since the lones cross the firewall, travel the length of the car, then cross back over.
