question about body damage please
ESPER
hello. i have a 95 s14 se and recently dented + scratched the bottom fender underneath the passenger side door! does anyone know of reliable import body shops within 350 miles of the bay area in california? AND/OR could offer advice as to how to take off the lower side under the passenger's door and give tips on how to fix the dent and repaint PLEASE?
all help is appreciated!
bodyman240
If your talking about the thin piece of metal under the door, that would be the rocker. I don't exactly know what area your talking about but I think that is it. In any case, it first depends on how bad it is dented. If its in a couple of inches you could drill holes grind around the area and fix with body filler. If its tagged it could possibly need a new rocker section welded in. I can only guess without looking at it. Hope that helps you out. About cost, that depends on the place you take it to.
