MinisterofDOOM wrote:German cars are definitely NOT contenders for most reliable cars on earth.
True, at least the BMW's require some mainenance and it can be a bit more expensive (not so much on the e36's it seems) if you're doing the work yourself. If you're having the work done be prepared to bend over.
If you keep up with things though they tend to prove themselves quite reliable during hard driving. From what I've heard the new Corvettes are worse as far as reliablility goes (at least on track).
The Bimmer engines seem to just take beating after beating. It's the auxillary stuff, electrical system, and bushings you need to keep an eye on. Very rarely does anything go wrong with my car that's major (mostly electrical gremlins). I've got 150xxx miles on my M at 7 psi from 30xxx and it runs great. Only twice in the past 2 years have I had anything happen that put it down to where I couldn't drive it safely. Once was a blown valve cover gasket and the other time was the result of the bearings wearing out along the driveshaft.
