Question about ball joints.
Spec-R
This might sound stupid to some but i dont know, do i need new ball joints if im swiching controll arms. im just replacing two bent ones(both front) and i have the ball joints in the broken ones. can i just press them out and press them into the new control arm? or do i need new ball joints??
continental_drift
Car: 1991 Nissan 240SX coupe - in progress - zeal function V6, ssr formula reverse, trust SP. more to come.
Spec-R wrote:This might sound stupid to some but i dont know, do i need new ball joints if im swiching controll arms. im just replacing two bent ones(both front) and i have the ball joints in the broken ones. can i just press them out and press them into the new control arm? or do i need new ball joints??
99% of the time, the control arm is sold as an assembly with the ball jointpressed into it already. If you bought used control arms thats ok, but getnew ball joints... if you somehow purchased new control arms which camewith no ball joints?? get new ball joints, don't use the old ones.
If you want some really technical answer, I'm sure kun or smith can helpwith that...but honestly, all you should need to know is that you don'twant to re-use the ball joints from old control arms, especially bent controlarms.
Red coupe
Car: 92 Nissan 240sx Coupe
Like he said I wouldnt re-use a ball joint...
But, IIRC Nissan doesnt sell front control arm ball joints, you have to buy the control arm and ball joint as one unit.been a while since I looked at mine but I dont think you could press the ball joints out to switch them.
Do you have the control arms yet, and did you buy new or used? They will probably already have a ball joint in them.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Red coupe wrote:Like he said I wouldnt re-use a ball joint...
Behold, PDM-Racing:
I bought my front LCA's from them, because you can't beat them for the price. They are Nissan OEM arms too, I dunno about the ball joints, but hey, they're in there and that's all that matters.
eddiec
Car: 91 S13
you can get ball joints seperate. although quality may vary. i got mine from suspensiorestoration and compared to the oem units they appear slighlty beefier. could have been an optical dillusion though..
skydragoness
eddiec wrote:you can get ball joints seperate. although quality may vary. i got mine from suspensiorestoration and compared to the oem units they appear slighlty beefier. could have been an optical dillusion though..
yeah, you can get the ball joints seperate, that's a given. However, they're usually between $30-$45 each, plus you need a press to install them or go somewhere where they do have one and pay extra moneyt to have it installed in the old arms. Or one could just buy the lca's brand-new with the ball joints already pressed-in for $53 a unit and have it be a bolt-on affair.
Red coupe
I guess I should have said oem...aftermarket generaly seems to give you what ever you want if you have money...
