question about auto engine to manual
kim
Car: 90 240sx, 97 M3
I was wondering on sohc ka motors from auto cars when you pull out the autotranmission pilot bushing is there anything else you have to change on there to put in the manual pilot bushing? The hole seems smaller then the manual pilot bushing or do you have to force it in there or something?
NISTECH
The bushing does not just slide in it needs to be tapped in with a mallet. If you alignment tool for the clutch is metal you can use that to tap it in. otherwise use a socket that will match the bushing diameter.
kim
Thanks nistech,
you are a true asset to this forum!
kim
