Question about Alternator Idler Pulley
CrimsonQ
Car: Purple People Eater
1990 Q45
Problem: Idler pulley on the Alternator belt has seemingly worked its way to falling off my car. Seems the bolt/nut jiggled off over time without me noticing.I have the pulley and the small disc shaped metal peice? cover? where the bolt/nut goes in.
Solution? I dont have the bolt/nut, only the pulley and disc piece.I see Joe has the pulley, but it says nothing about the bolt. My pulley is in very good condition, I just need the bolt. Is this bolt/nut something I could get at a local parts store? Id love to have my baby running this fine sunday.
Also, do you guys remove the rad fan and shroud to get down in there? or is my arm just really fat? I cant seem to even be able to get it in the area down there.
Mucho thanks on any suggestions.
Modified by CrimsonQ at 11:36 AM 12/3/2006
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Usually accessed from below on a lift after removing the windage tray.
Just pay attention to the parts diagram and be sure you have the correct components assembled in the correct order.
CrimsonQ
Thanks Brian. Looks like Ill be tackling it later in the week. 18 degrees out here doesnt sound like fun
DetroitJazzMan
Car: 1994 Infiniti Q45A
2002 Nissan Maxima SE 6spd
1940 Cadillac 62 Series
1953 Cadillac 62 Series
1961 Cadillac
73 Ford Mustang Q code conv
send me your address and a couple of dollars to'[email protected] and I will send you the bolt. Jazz
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
CrimsonQ wrote:Thanks Brian. Looks like Ill be tackling it later in the week. 18 degrees out here doesnt sound like fun
Heck, I am not even handling 50 with wind.
CrimsonQ
DetroitJazzMan wrote:send me your address and a couple of dollars to'[email protected] and I will send you the bolt. Jazz
Will do! THanks
