Rex »
https://forums.nicoclub.com/rex-u6324.html
Tue Feb 08, 2005 6:38 pm
Thanks, but as my Dad would say, I know just enough to be dangerous . Okay, maybe a little more than that.
Bridging an amp on a 1 ohm load if it's not rated for that will shorten it's life, depending on the brand it could make it real short, think boom fizz (lights out), others will just blow the battery/amp fuse. You could bridge it on them (series config), but that would most likely seem like it wasn't hitting as hard.
If you're going to stay with "stereo", then you want to leave the speakers wired to the amp in a normal/straightforward mode. Just make sure the wires aren't criss crossed inside, causing the out of phase condition I think you have.
The 2 speaker cups would lead me to think your box is wired in stereo.
Even if the subs were in their own space (seperate/divided boxes), being wired out of phase (with each other) would still cause it to sound "less" than it should.
It also happens with mids and tweets when they're wiured out of phase to one another.
Hope this all helps and you get things going right. I'll check back tomorrow.
