trokita »
https://forums.nicoclub.com/trokita-u99826.html
Tue Aug 28, 2018 12:31 pm
Going by your signature I assume you have a newer Rogue (T32). I have seen people run the Infiniti 37 19x9 +45 wheel front and rear. With the correct size tire 245/55/19 or 245/50/19 depending on taste. You should be fine. Your not lowering it so no need for fender roll. You may need a minimal spacer in front, maybe... On newer generation Rogue, I wouldn't go much wider than 9 in front and 9.5 in rear. I have however seen a 10.5 in the rear. Previous generation rogue (T31) was good for 9.5 width front and rear. My setup is 19x8.5 +38 Front Nitto Motivo 245/50/19 , 19x9.5 +43 Rear Nitto Motivo 255/50/19.
