the vlsd doesn't affect your speedometer.vutony wrote:I bought an '92 SE S13 with Vlsd in already but the odometer doesnt read correctly, its about 10-15 mhp faster. Is there a way to fix it? Not sure wat if came off of but it has 5 bolts on the axles so I think is from a J30 or Z32 but not sure. Plz help, thanks in advance.
When i did my swap it was convention to change the speen sensor out. Am I wrong about that? I thought that was one of the things you just had to do... Has the consensus changed? I've been off the boards for a while.SpeedRacer1 wrote:The speed sensor from the SR and KA are the exact same. The part numbers are the exact same. The gears have the same number of teeth.
