http://www.redlineoil.com/product.aspx?pid=140&pcid=7SHIFT_COUPE wrote:I STRONGLY suggest using REDLINE's product for our trannies. It makes the shifting BUTTER SMOOTH.
You should use a mixture of 60% MTL /40% MT-90 manual transmission fluid to have the right viscosity. I found out that this ratio is the best one for me.
The mixture of redline oil
Nissan calls for API GL-4 oil with 75W-85 viscosity. We want BUTTER SMOOTH,so we'll be using Redline fluid, but since they do not offer the exact oil viscosity we'll need to mix them:
Tutorial by mcheddadi
MT-85 75W85 GL-4 Gear Oil - Recommended for Nissan 350Z and 370Z (also most Maxima, Altima & Sentra),
Did redline just make this? Id rather have one made by them then make my own.
