question about 95 240sx
dizzywithsunstroke
Car: 1995 Nissan 240sx w/ RB20DET and 1997 Nissan Hardbody
there is some kind of sensor under the stock airbox in a 95 240sx. it says "unisia jecs" on it. does anyone know what this is? thanks
juvenile138
its probably the IAT sensor which is just an air temperature sensor, the only other thing connected to the air box is the mass air flow meter which is connected to the top
juvenile138
dizzywithsunstroke
no its not that. it is a small metal box on the top side of the wheel well that is about 3/4" x 3". it is attached to a wiring harness with the sensor on the power steering line on the driver side framerail.
juvenile138
I bet its this thing, you have an automatic? I know this is on the driver wheel well, little silver box
supratt1001
Car: 96 240sx se
never even noticed im have to check it out
dizzywithsunstroke
thats it. what does it do? does it hook to the automatic transmission computer?
juvenile138
It apparently is what regulates the line pressure in the transmission, not sure if its just the pressure in the cooler line or some internal pressures or both.
