T45 wrote:Will do. Not sure it's a miss though, it feels like I glued a 2lb weight to one side of the flywheel. Not sure where my problem lies. I used the VH spacer and ground off the tit on the crank so I don't think the flywheel is off. I am baffled. How hard is it to tell a miss on the VH? It literally feels like something is out of balance.
I've been chasing injector issues since I've had my Z together. When its down a cylinder you can sorta make out the noise and the motor feels sluggish, but when its down two it feel like its going to rattle itself apart.
So for me, it's easy to tell if there's a miss. The sound is the biggest indicator, vibration is a close second.
If it's missing all the time it's probably not your knock sensors, but the KS can make the motor break up and heasitate at part throttle and such.
Still worth looking into IMO.
