question about 5zigen FN0R1 wheels
Shabbernigdo
I just got me some wheels for my s13 and they came with these screw togeathere valves stems, Do they work well? also do i need to put anything on the rubber gaskets to help them seal better?
Can standard rubber valve stems not be used on these wheels?
ty for any info.
onosqv
Car: '92 240sx Vert
I need to see a picture bcs I'm not sure what you are talking about. All the people I've seen w/ 5zigen rims have the standard valve stems - nothing special from what I remember.
As long as it holds air, it should be fine .
naed240sx
Car: .....
brokeAs240sx wrote:I need to see a picture bcs I'm not sure what you are talking about. All the people I've seen w/ 5zigen rims have the standard valve stems - nothing special from what I remember.
He is talking about the bolt-on valvestems. Pretty much every aftermarket wheel that I have seen uses them instead of the push in type. They work fine. The cheap push in ones can be used too, as long as the edges of the valvestem hole are not too sharp.
onosqv
Car: '92 240sx Vert
i c, weird. the only aftermarket wheel i got new was the push in type. and the other 3 I've had used were all push in type too. Learn something new every day, haha.
