evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Nov 29, 2009 8:10 pm
the nissan turbo's have always has unique flanges, the Z32 came with 4 bolts, at least mine did
if you are looking to replce your ailing turbo's new center sections is your best bet, you can get new center sections that use your nissan specific housings and all the moving parts are new, if you are looking to upgrade you can get new upgrade center sections and have your housings machined to accept the larger center sections, this is how most upgrade turbo's are built, the T28's use adaptors, and require you to convert to 5 bolt downpipes which are available if you want to run an off the shelf turbo but you'll still need to adapt the turbo inlet and outlet on the compressor side as they are also unique to nissan
