question about 350z/370z transmission on an rb engine
ivorton23
Car: 1996 Nissan Maxima SE 5 speed
does anyone know if a 350z/370z 6 speed transmission can be bolted onto an rb25 or rb26? me and a friend were talking about swapping an rb25 into a 240sx s14 and was wondering if it could be done.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
why not keep the 25 transmission? you want a six speed for what reason?
use the stock n25 transmission and use the extra money youd be spending on mods to motor,
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Not without an adapter plate and modifications to the input shaft. I'm guessing on these things, but they're educated guesses. If you can do it for less than the price of an RB25 transmission, go for it.
And please tell me you're not trying to do this because of the 6-speed transmission.
SullivanRacing06
Darius wrote:Not without an adapter plate and modifications to the input shaft. I'm guessing on these things, but they're educated guesses. If you can do it for less than the price of an RB25 transmission, go for it.
my thoughts exactly about the
Carl H
hybrid bellhousing using an rb20de/t bellhousing.you wont have a speed sensor so good luck on your actual speed.
DriftingisLame
Car: '91 240sx coupe, rb20det
Good luck on finding a 370z trans, you'll spend as much on one of those as you would an rb26 swap.
DETurbine
Car: Nissan S13 RB25
Carl H wrote:hybrid bellhousing using an rb20de/t bellhousing.you wont have a speed sensor so good luck on your actual speed.
Or you can use a Z32 transmission....swap the bellhousing with your RB25.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
DETurbine wrote:Or you can use a Z32 transmission....swap the bellhousing with your RB25.
If I was building my car for street or cruising, I would do the 6sp, but I'm not. As long as you could get a matching differential ratio, that is.
Carl H
compared to the z32 trans which is identical in almost every way the z33 6spd sucks and you will be shifting ALOT.
Shocker
Car: 89 240sxHB rb26/30
Carl H wrote:compared to the z32 trans which is identical in almost every way the z33 6spd sucks and you will be shifting ALOT.
q45 rear end it? Granted the adapter plate was there..
Heres the z32/r33 ratios
3.21/1.93/1.30/1.00/0.75
Heres the z33 6 speed ratios
3.79/2.32/1.62/1.27/1.00/0.79
I like the r33 ratios better myself... However SP is proving the z33 six speed can handle some BIG power right now. Making 1250rwhp through it.... Very impressive. However they have stated they feel its a ticking time bomb... along with the z33 rearend...
Carl H
like i said you'll be shifting alot even with a q45 final drive.
ivorton23
yeah i think i'll stick with the rb25 5 speed. i just wanted to have a 6 speed, plus i thought the 350z 6 speed would be able to handle big power from a built RB engine, but guess not. thanks guys!
SullivanRacing06
the rb25 transmission is a very strong transmission, same gear sets as the rb26 and z32 transmission, stong gears, good gear box, stick with it
