Question about 300z brake conversion???
Takeoff
Car: 1993 240sx
I have searched and have not found an answer to my question. Why do you need to use the 300z ebrake assembly to do the rear brakes? The fronts are a pretty straight forward bolt on affair but why not the rear.
I also have another question pertaining to converting to s14 spindles. All I have to do is change the lower ball joint in order to use the s14 spindle on s13, right??
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
On the 240 the P brake was used via the caliper... So that said, you CAN bolt on the reras and theyll work youll just have no parking brake.....
Red coupe
Car: 92 Nissan 240sx Coupe
to expand on what he said the 300zx uses the inside of the rotor hat as a drum for a separate parking brake...So when you remove the stock rear caliper you are removing the e-brake assembly as well, and you need a different set up for the 300zx brakes/rotor
