Question about 2013 Rogue AWD
jryka
What happens when I lock my AWD on? Is it now like a 4WD?
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
use the search function please.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
RTFM
hjb
Hi,
I just bought a used 2013 Rogue AWD, if I turn on the AWD lock button it only stays lit until I hit a certain speed....then the light goes off....does this mean the awd is off
and it is back in 2wd or does the light just turn off??? is there any way to keep in AWD??
thanks
kboo74
Car: 2015 Nissan Rogue SL AWD Premium Pkg (Former)
2017.5 Nissan Murano SL Tech Pkg) (Former)
2019 Acura RDX A-Spec with Tech Pkg Performance Red
Its working as designed. It only stays on when the road conditions warrant it being on after being turned on. My 2015 Rogue does the same thing. If you have the owners manual its explained in there.
Ken
mpattdu
Car: 2008 Nissan Rogue SL AWD
The Rogue's AWD system is designed to be a part time system. You're in AWD when you first start moving and then the system shifts to FWD and stays there until a slip is detected and then AWD kicks back in. The AWD lock is for when you're covering rough or slippery terrain at a slow speed. If you exceed the max speed (I forget what it is exactly but something like 15mph) it switches back to the AWD Auto mode. The AWD Lock/Auto button is explained on page 5-23 of the owner's manual: https://owners.nissanusa.com/content/te ... manual.pdf
Rogue One
2022 Honda Pilot SE
I'm guessing your Rogue didn't come with it's owner's manual.
Section 5-24 - Starting and driving (pg. 256):
LOCK mode will change to AUTO mode
automatically when the vehicle has been driven
at a high speed. The AWD LOCK indicator light
turns off.
What it doesn't say, and I can't remember for certain is, does it turn off at 15 or 25 mph.
2013 Rogue Owner's Manual (Download PDF)
Comprehensive information on the operation and maintenance of your Nissan.
2013 Rogue Quick Reference Guide (Download PDF)
The quick and easy way to get to know your Nissan.
Return to “Rogue Forum”
