bakerboard wrote:Well I turned over the key three or four times and it just tries to start but it sputters. My battery is 2 years old... A few months from 3 years. I'm going to see if my water levels are Ok in my battery then go from there. I tested the voltage on the battery when it was off And on. Off = 12.63 and ON = 14.73.
Yes i have the extended warrenty too so it would be covered. I would like to try and fix it myself if i can so i can learn how to do it but if i cant then ill take it in.nametakennow wrote:Starter/anything significant that could fail in the starting process ought to still be under warranty for an 07, right?
Should i be looking at geting new spark plugs then??nametakennow wrote:Fuel or spark. If it's turning then it's not the battery or the starter. It's the actual ignition process, which is plugs (or coils) or fuel (pump, pressure reg, injectors come to mind).
Also, when you go to the Nissan dealer try to get a test drive on the new 09 GT-R.bakerboard wrote:So i was talking to a family friend who is a mechanic and he said that.. if the spark plugs are that hard to get to then they are prolly life time spark plugs and i shouldnt have to change them. I looked in the owners manual and there it said that the spark plugs are platium tipped and should not have to changed them as much as regular ones. He then asked if i have changed the fuel filter or air filter at all because that could be giving it a rough start. I talked to my dad and he said he hasnt changed yet.... so im going to take the car into nissan and have them do the 45,000 mile maintance check...
