Quest Alternator wiring Diagram!
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Can someone take this picture and Label the Correct wire that hooks up?
I have my battery ran to the bolt in the back and my brown plug plugged up to the terminals. But Im not sure that the brown plug is correct, with the correct wires.
So can someone verify what hooks were. Thanks
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Don't forget that you'll need to ground the rear of the alternator to the chassis too. It looks like it is plug and play.
rb25drag
I didn't ground mine. Could this be why im Overcharging? I figured it was grounded to the block?
Darius
I am not certain, but my KA and my RB both had the alternator housings groudned by a separate wire. Give it a shot because it can't hurt.
rb25drag
Ok thanks, Ill give it a shot. Now what does the brown plug wires do? I can un plug mine and it makes No difference. So I might not have it wired correctly.
Darius
Does the battery light in the cluster turn on when it is unplugged? Here's the charging schematic from the 91-94 FSM:
http://s118.photobucket.com/al...c.jpg
Damn photobucket downsizing my bitmap image!
Modified by Darius at 4:18 PM 5/6/2008
Shocker
Car: 89 240sxHB rb26/30
Yeah ground wire needs to be hooked up to a screw that goes in the back of the ALT, its how its supposed to be....
Could be the over charging issue right there....
gawdzilla
Car: none
you need to ground the alternator using that screw. you also need that brown plug. one wire of the brown plug activates the light in the dash. the other wire controls the charging.
rb25drag
Do you know which wire? I think mine isn't working.
gawdzilla
Car: none
W/R wire is the cluster lightY wire is the charge voltage
this is for s14 but hopefully its the same
wawazat8402
Car: 89 Sil80- RB25DET
According to the schematic posted above the w/r wire goes to the cluster.
rb25drag
Found the wiring problem. I for got I used a plastic twist bung connector when wiring the alternator plug. Well turns out it wasn't getting connection. Re-wired and it works great now. car sets at 14.4 volts and is smooth again.
BoostFab
Car: S13cp, S13fb, S14z
you can get the plug from the dealer, for a clean install
rb25drag
I Had a factory plug already. Just needed to install it. So it cleaned right up and seems to be fine now.
mentordrift
Car: 1995 Nissan 240sx SE
dont you love that Quest alternator? haha
rb25drag
I really don't see a difference! Just I finally got all my wiring fixed I think LOL. But im sure it plays a big roll.
rossmac
Just found this, anybody know where i can get that pic i think it will help with my alternator wiring issue:DThanks Chaps
