quest alternator upgrade
Cpt_Impossible
Car: G35 6MT
How much are we talking? $50
I don't have a spare bracket though.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
Yea that sounds fair but i dont know if i have a spare bracket on my shortblock. Ill check tomorow and see if i have one.
HOMEMADE240SXTURBO
Car: 1989 NISSAN 240SX KA24E
was
mott6904 wrote:Yea that sounds fair but i dont know if i have a spare bracket on my shortblock. Ill check tomorow and see if i have one.
I know this thread is old but, is that for an rb20det?
Cpt_Impossible
Car: G35 6MT
Yes
devil_child
since this was brought back up, you can do the mod to slot the bracket to fit a ka alternator, and the quest alternator pretty much is bolt-on after that. since the pulley was a little crooked on mine, I took a litttle off the front of the mounts on the alternator housing with a grinder and put a washer behind the bottom mount to push it forward.
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
I made this swap work perfectly and has held up for half a year now with no problems period. I did not have to weld a single thing either.
Ill post a write up when i get around to it here soon.
HOMEMADE240SXTURBO
please make a write-up
devil_child
just use some imagination and a grinder.
ripracer
Car: 01 Dodge Ram & 91 s13 hatch
Went to 2 junk yards and yet to find a Quest Alternator.
So I decided to try the J30 deal and it didn't work at all. The covers look very similar but trying to swap them wasn't going to happen. The rb20 was just a little too big for the J30's internals. Not sure what year j30 I pulled it from, but I would imagine they are all the same.
So I'm back on the hunt for a quest and out $20 bucks for the J30 which I guess Ill just use as the core.
ripracer
Pulled this off tonight. Took back the J30 found a Village alt. for 15 bucks and little drilling of bottom mounting hole and just cut and weld the Quest/Villager bracket to the rb20's
I suck at welding but hey cranked it up and shes putting out 14.16v, but sadly on stands, hopefully tomorrow. Maybe this solved some of my little issues.
devil_child
so my quest alternator took a **** today.
gawdzilla
Car: none
finally got around to doing this with the quest 125a. got it to work but probably would've been better to make my bracket so i could go back to the stock RB alt if i wanted to. someone posted on page 1 with that method.
i had to grind down the lower bolt hole spacer piece as well as the block mount to clear the alt housing. otherwise i couldn't even put the lower bolt through to get the alt to hang on there.
yet to start it up but everything is tensioned and mounted
StricNyne
what year was the 125a i thought it was 105 and 110 ? sounds good i got an quest alt idk wut year but i was waiting on my alt to take a **** first
gawdzilla
Car: none
StricNyne wrote:what year was the 125a i thought it was 105 and 110 ? sounds good i got an quest alt idk wut year but i was waiting on my alt to take a **** first
i'm not sure... i bought mine off ebay remanned to like new for $90 shipped. on the ad it says 93-98 quest/villager and claims it's 125a. not sure if i can verify if it really is 125a.
ninety1two40
Car: 1991 240sx SE
gawdzilla wrote:finally got around to doing this with the quest 125a. got it to work but probably would've been better to make my bracket so i could go back to the stock RB alt if i wanted to. someone posted on page 1 with that method.
I can provide more details if anybody is interested with my method.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Yes please elaborate. And do you have any better pics that you could take to show what you did. I'm planning on having something fabbed up on Monday night.
ninety1two40
Car: 1991 240sx SE
Ok, I don't want to remove the bracket but I'll take more pics and make a diagram. It's really simple.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Stock _is_ 110a for a 94 Quest.
The only way that I know of to verify the amperage would be to remove the alternator and set it on a test rig.
gawdzilla
Car: none
ninety1two40 wrote:Ok, I don't want to remove the bracket but I'll take more pics and make a diagram. It's really simple.
ugh the more i think about it the more i should've done it your way. just requires a bit more hardware but being able to go back to oem is key.
Darius - start with the mock up first. get the alt swinging on the block (that takes a bit of effort). then once you have it swinging you can really see how the bracket is to be made.
l0nestar wrote:Stock _is_ 110a for a 94 Quest.
i was thinking maybe different models of Quests with different options that require more power.. i dunno like rear stereo/accessories might have them offer 2 different alts amperages. not too sure. but either way it's an upgrade and remanned part to replace old.
BoostFab
Car: S13cp, S13fb, S14z
let me guess, you're using spacers LOL
gawdzilla
Car: none
BoostFab wrote:let me guess, you're using spacers LOL
he made an adapter bracket that lets you tension the quest alternator using the RB tensioner setup. it is a great idea. i can see what he did but its difficult to tell if you hvaen't played much with the setup:
ninety1two40 wrote:I know this is an older thread but it seems like a good place to post this so people can find it easy.
I used an alternator from 1996 Nissan Quest.
Instead of chopping up the stock alternator bracket I decided to make an adapter that would allow me to still use the belt tensioner and give me the option to go back to the stock RB25 alternator. I had to enlarge the lower mounting holes on the alternator. But I didn't have to modify the block or the alt bracket.
I basically welded two angle pieces together and drilled two holes. I'll try and get a better picture soon, but all I had at the time was my camera phone.
BTW: I'm still new to welding
ninety1two40
Car: 1991 240sx SE
Ok I took like 4 pictures but only one is clear enough to tell what's going on. Also, I had it powder coated a few months back when I had my valve covers coated.
I'm going to look around for a piece of steel and just make a quick "how-to".
ninety1two40
Car: 1991 240sx SE
Here's a quick write up I made, nothing fancy but I'm sure it would answer most of your questions.
http://www.kloptech.com/hostin...t.pdf
BTW, I have been running this setup for about a year and no problems what so ever.
Modified by ninety1two40 at 6:34 PM 8/2/2008
Modified by ninety1two40 at 6:45 PM 8/2/2008
l0nestar
2004 Toyota Altezza
Good idea writing a PDF!
gawdzilla wrote: i was thinking maybe different models of Quests with different options that require more power.. i dunno like rear stereo/accessories might have them offer 2 different alts amperages. not too sure. but either way it's an upgrade and remanned part to replace old.
I had wondered about that as well, but there is only one part no for a Quest or Villager.. and it is 110a. At least according to Napa, Advance, and Auto Zone. We just got an O'Reily.. I did not check there..
ninety1two40
Car: 1991 240sx SE
l0nestar wrote:I had wondered about that as well, but there is only one part no for a Quest or Villager.. and it is 110a. At least according to Napa, Advance, and Auto Zone. We just got an O'Reily.. I did not check there..
I noticed with some alternators that I have bought from Advance Auto and Car Quest, put out more power than is listed. Most new alternators come with a data sheet and plot of the output current vs. rpm. Every alternator isn't exactly the same.
Darius
Wow guys. I didn't realize how much of a PITA this upgrade would be. It sounded like "eh, drill out the alternator hole, grind the block a little, make a bracket and POOF! it's done." Not that easy.
I had to grind the block down about 1/8" on the outside of the lower mount. Then I had to grind the spacer flat on one side taking about an 1/8" off of that. THEN, I had to sand down some of the alternator housing ribs to get it to clear. And it still interferes a little on rotating it. Totally sucked. Took two guys 4.5 hours and a full machine shop...way longer than expected. Even after all of that, the lower bolt is too short to tighten down the alternator and I ended up having to slap the stocker back on to drive home. Pissed me right off!
I will say that the bracket we made is 10X easier and cleaner than anything I've seen so far. Check it out below! (2" of 1/8" steel flat bar, ~4" bolt, ~1.5" of spacers, nut, and a short bolt matching the threaded alternator hole)
Here are some camera phone pics of what I mean.
Alternator comparison
Rear bushing swap (simply pressed in there)
Ground spacer
Bracket
ninety1two40
Car: 1991 240sx SE
Looks good Darius
Darius
I'm at work right now and want to go to the hardware store to get a longer lower alternator bolt. Does anyone know the size/thread of this bolt? I can check it tonight, but I wanted to save some time.
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
SEARCH NOOB!!!!
Darius
ohhh LOL coming from a newb NRRBA member! Have you paid your dues yet buddy?
