Quest alternator kits
sepulchralx
Car: 240sx
I'm going to be upgrading my alternator and unlike a few, I have a welder at home, so I'll be fabricating a bracket to use the quest alternator. I'll also be picking up a few alternators as well. They're not new, but used or remanned.
I was just wanting to gauge interest because If i'm going to make one bracket i can make several.
Kit will include:
Alternator - Quest 125AmpAlt Amp FuseCustomized bracket attachmentDrill Bit for Reaming the mounting holes
You may have to grind your block a little bit, you can get a angle grinder with a few wheels for about $14 from harbor freight or Northern tool.
my price would be $150 shipped... email me at [email protected] and CC to [email protected] if you are interested,
thanks
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
or you can just make the stock bolt holes a little larger and make the slot a little longer and its a perfect fit with the stock bracket. Took me about 20 mins to have it ready to bolt the quest up.
sepulchralx
Car: 240sx
rb25drag wrote:or you can just make the stock bolt holes a little larger and make the slot a little longer and its a perfect fit with the stock bracket. Took me about 20 mins to have it ready to bolt the quest up.
post a pic
homesivan11
Car: 1989 Nissan 240sx with a RB20DET swap
I did the same thing... drill the hole bigger and i used a couple washer, and works good...
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
i want to see your kit. Ive already built mine, just curious to see what you came up with.
neonbomb
Yes post some pics
ninety1two40
Car: 1991 240sx SE
sepulchralx wrote:I'm going to be upgrading my alternator and unlike a few, I have a welder at home, so I'll be fabricating a bracket to use the quest alternator. I'll also be picking up a few alternators as well. They're not new, but used or remanned.
Kit will include:
thanks
The brackets are easy to make, check out this write up I made: http://www.kloptech.com/hostin...t.pdf
