Quest2004 »
https://forums.nicoclub.com/quest2004-u265585.html
Wed Jul 13, 2016 2:04 pm
Those funky looking roof racks on the 04-06 Quests (gray round bars) look pretty sturdy right? Welllll...yes and no. The bars themselves are great and very strong. Howeverrrr, the way they attached them to the roof? That part is a little soft for heavy loads.
They rest on plastic mounts that are held into the roof sheet metal with ONE solitary nut/bolt at each mount point - four nuts and bolts total for the two bars. That's right.. one - and its is not a heavy duty screw. This screw goes into the bar, down thru a hole in the plastic, and thru your roof sheet metal - with a routine nut holding it down behind the headliner. No matter what anyone at the dealer tells you - at least for 2004's - that sheet metal is NOT reinforced at all. There is a hole, a bolt, and a nut. That's it. Those other two nuts/bolts that you see on the plastic part in pictures only hold the plastic to the roof - pretty useless. They should have used TWO bolts on each mount point thru the bar (eight total), but that's just my opinion and what do I know..
Also keep in mind that that plastic ages and becomes brittle - all four of mine were cracked pretty bad so I replaced them. I also put one of those rubber spring spacers (for suspension coil springs) on the roof between the bar and the roof sheet metal right next to the plastic mounts at all four ends. This took the load off of the plastic and put it on the rubber (I used Superior RideEFFEX - Spring Boosters from O'Reilly). To install you shave off one end on a grinder so the curved rubber side seats with the bar. The other side that rests on the roof you shave flat. Shave them right and put a light lubricant on them and they will slide right in - keep them snug. (I'll find a picture and post)
