Quest 125 Amp Alternator....
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Ok, I was in the junkyard, and I wanted a 110 amp alternator to put in my car.. I came across a 125 amp alternator thinking it was 110..
I pulled it, and actually matched it up to my RB20 alternator..
It looks like a close if not equal fit.. I will test fitment tomorrow, it looks like it will bolt straight up..
If it works, I will let everyone know the part number :-)
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
damn lucky.
i pulled a 110 amp alt out of a mercury villager (same one as the quest)
Acecool
Trying the fitment in a little bit.. I am sick, and have to do a few more errands!!
Ill try to take pics as I am doing it...
Acecool
Well... It lines right up..
The bracket needs to be straight and not curved, and the bolt at the bottom needs to be longer..
Other than that.. lol!
So it will require some mods!
Acecool
Ok everyone..
It bolts STRAIGHT UP.. except for a few things..
If you have notched your bracket for KA alternator, you will have to do a minor alteration to the bracket again..
These mods need to be done:-----------------------------1) Drill another hole in between the 2 mounting holes.. really close to the one on the end. (Needs to be done, otherwise belt would be HUGE.. closer you drill this to hole that mounts on bottom of bracket, the shorter the belt needs to be.. keep in mind if its too close you will need to chop the end off because it will come in contact with the water pump)
Use that 1 hole to bolt the bracket on the car at the water pump (use the lower of the 2 you would normally use)..
2) Drill a wider hole for the alternator bolt to go through the mounting holes (at bottom of alternator)...
3) A slightly longer bolt (.5 inch)
4) Longer belt needed
Use the STOCK RB20DET flanged spacer thingy that came with the motor...
Bolt it up and enjoy 125 amps :-)
Pictures to come tomorrow..
So, if youw ould rather drill 2 holes, buy a longer bolt and a longer belt instead of fabricating a bracket.. this is for you!
db_s13
Car: 92 VQ30DET 240sx
what car is this off of again...
Acecool
Came off a quest...
Here are the numbers off the alternator...
Exactly as seen...
29100 (9 might not be 9.. its hard to see) 7B000XF52-10300-ACA3TA5891ZC12V 125AMitsubishi Electric Automotive America (U.S.A.)
