Quesiton for anyone with AC and SR
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Has anyone got it to work? Well I mean hum....did the compressor that came with the SR work and did it use the R12? Did you use the condensor and evap from the KA? Thanks for any input or information you have. Im thinking about going to an SR cause I have a 92 S13 so was hoping that I wouldnt have to change anything on my AC system.
badass240sx
Yes you can use your KA compressor. Only two of the bolts will line up but it'll still work. Or you could use the SR compressor and custom fab lines and rvcr drier location which in total will cost around 350-550 depending on where you go and if your doing it yourself, etc. Also could have been found by a simple search, btw.
Tai Mai Shu
I used the Redtop compressor with KA lines KA everythign else and spent 65 bucks a pound for the R 12 stuffs but blows so cold!
S13240
Tai Mai Shu wrote:I used the Redtop compressor with KA lines KA everythign else and spent 65 bucks a pound for the R 12 stuffs but blows so cold!
How did you make the ka lines fit onto the sr compressor?
Tai Mai Shu
Had them match the SR ends to the KA lines.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
I have an s14-s14 swap. It didn't look like the KA compressor would fit in the SR comprssor's place and I never got the SR lines. What is my best bet- Try to source down some SR lines and retrofit them onto the KA ones? Or try to bolt the S14 KA compressor onto the S14 SR engine??
hokiruu
Oh yeah, are the end fittings on s13, s14 lines the same? Just wondering because if I am looking to buy lines, I better know they will fit, ans just s14 lines may be rare.
