InsanityInc wrote:I have a 3 inch cat and catback on my car with the stock manifold. All the flanges connect just fine. That dyno is of just the catback with the stock converter, though.
Look on the distributor cap. Mine has the numbers stamped into the plastic.
Also, the firing order will 99.9% of the time be 1-3-4-2 for a 4 cylinder, so you definitely want to arrange it in that pattern. I'd just try it in all 4 possible locations of 1-3-4-2 until it started. Also, you may have flooded your engine with gas by this point, so try giving it gas when you start it.
so you had a 3in muffler aswell?
and the 4,3,2,1 setup i got runs fine is it not supposed to??
