Bumnah wrote:Get a new shell
Co-signed. I got a cut out section of another S13 to do my driver quarter with over the summer and had a friend cut out my bad section and weld in a good section from the clip. I even helped and we had 16 hours of work into it. Also when you weld in a section, the metal you cut out of a good clip is going to have a 'memory', and want to keep curving where it curves. This will create dipped in sections you need to fill in with filler after the tack welds are ground smooth. I can post pics of the whole process. Anyone want to see?
