I have had a 94 vert for about 8 years now, just bought my second 94 vert.
On my new purchase, the rear windows will not go down/up when using the window switch. I swapped out with my other convertible switch and had no luck either.
Where I am stuck- I removed the console/armrest and unpluged where the switch plugs into the wiring. If I apply power/ground to the correct wires on the switch the windows will happily move up and down.
BTW, the previous owner has already done the seat belt piller removal and swapped the power windows to crank windows. Not sure if that would be related at all to the quarter (rear) windows not working with the switch.
Fuses are good.
Thanks.
