Quarter Panel Repair Possible??
GaMBiTx
Hi,
Someone hit me from the side, is the damage on the quarter panel repairable?? Cost? Also the vehicle hit the rear wheel causing it to be bent slightly. Depending on what it is? Anyone know how much it would cost to replace axle or the arms. Thanks.
420sxWETDREAMS
Car: 1991 240sx Hatchback
mine was more smashed in almost to the hatch lining and mine looks flawless...so yes!
GaMBiTx
hey, u went to shop to do it or did it yourself?
EnjoiNismo
Car: 93 240sx
Hello parts car.
Lots of work involved to fix it, and sometimes its not worth it.
rsmithdrift
Car: 1993 240sx fastback se.
A insurance repair shop would charge in excess of 4,000 dollars to fix that.
I have QP damage not near that bad. Only deformed after the rear tire and my quote was 3,432.16 They said to fix it properly they would have to cut out the entire rear section of teh car and weld in a new one from a donor car. And that quote was for me supplying the parts... so ... yea. that's bad. Unibody ftl
Or you could go the cheap route and have it redneck repaired under the table if you can find a willing mechanic to do side work for you. Then it would cost only around a grand or so. And would look almost the same as it did before the accident but their would be subtleties to give it away still if you knew what to look for.
Choice is yours my friend.
mixeds14
Car: 240
dude, on the tire u can find the arm or link that got bent for cheap. look on the brake/suspension forum.
a body shop will only charge u that much ^^^^.. what he said b/c it a Insurance JOB, if u paying out of packet they shouldn't charge u no were close to that... just go to a shop thats legit n not out trying to screw people, but that can definitely be fixed, u can bang it out n bonded it out, that would be ur cheapest option it ur tryin to do it yourself or find someone that knows what they doing n cut out the cp an weld the new one on..
420sxWETDREAMS
if you read my thread I explain in detail......but had it done by a shop.
420sxWETDREAMS
I paid $400 out of pocket
420sxWETDREAMS
he wanted $1,200 for the body and paint
troskinatior
Car: A Two Tone Piggy Coupe
Well if they hit you why dont you bring it to a shop and let there insurance cover it?
But you would probably need to get a quarter panel and weld it in. By brother has his 1/4 smashed in just not as bad and all the shops said he would need a new 1/4 panel
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
i have two pristine rear quarters on my hatch im parting out. it has front end damage only. if you need quarters man shoot me an offer, if not the car is probably gonna get scrapped with em. heres some pics man let me know.
gar732
Car: 97 240sx
Its probably a total. If you were hit then they are liable. I'd say take the cash and find another car. The quarter needs to be replaced and if its not something you've done before I wouldn't attempt it. Used quarters are no fun either, you have to drill out all the spot welds and be careful not to damage it taking it off the used clip. If you decide you want to do it anyway ask alot of questions before you start hacking it apart. It'll save you the hassle of having to repair your own mistakes. I work at a body shop and do quarters all the time. Its not bad if you have the right tools and know what you're doing otherwise it can be a mess and you'll end up with a job you're not happy with. Also beware of those that are willing to do it dirt cheap, you usually get what you pay for. If you got questions ask away.
