centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Feb 26, 2016 12:23 pm
Stock engine? Which engine?
I noticed ISIS pump does not come with new studs. I like new studs with a pump. I typically have one broken already or snap during replacement. I also noticed ISIS is distancing itself from the terrorlst organization and is now ISR. Good idea! I wouldn't be surprised if ISIS is same as parts store brand, repackaged.
I'm not positive about all 240s, but in my experience, the water pump on my KA24DE's have used liquid gasket and I've always had to scrape off old liquid gasket, so no paper gasket seems normal.
I have only bought water pumps from parts stores. They are affordable and functional. I've yet to have to replace one more than once, so IMHO, they are reliable, non-performance enhancing parts. That's my personal experience.
You can upgrade hoses to silicone, you can get higher temp thermostat, higher temp radiator cap, different radiator, change fans, change fluid, and or put a different pulley on the water pump. I don't know why you'd want to spend $$ on anything more than a basic pump, but that's just because I don't know what I don't know. Maybe someone else knows more.
