IvanAtSPRacing wrote:There are so many things that you have to watch out for with an FMU car.
First you have to look at how well the fuel pump will supply fuel at higher pressures as we discussed previously in this thread.
Then you have to see how the injectors will react to these pressures. The more fuel pressure on the pintle, the harder it is to open. At some point, the coil will not be able to lift the pintle any more or in some cases, the pintle can be held open and not be able to close.
You have to also look at how your fuel lines and clamps will handle the pressure. If you partially blow a hose off in tank, you will not know till your motor is melted (unless of course you have a fuel pressure gauge in the car)
Amp draw is another concerne. The higher the pressure the higher the Amps. This can blow fuses and can also cause wires to melt.
Don't forget the loss of lifespan to the fuel pump itself, working against the pressures necessary. FMU is a bad way to go, and 12:1 is improbable. Even 8:1 creates 110psi pressure at that boost level (8psi). The way to go is bigger injectors with a piggy back system. Call Boost Designs and ask to NOT pay for the FMU or any other unproven items that are the lifeline of a turbo kit. Like a generic wastegate. You should save ~$100, and use that towards a tried and true Tial wastegate and S-AFC with larger injectors. If you do it right the first time, it'll cost more up front, but you won't have to pay alot more total down the road. And have additional downtime during the upgrades, and labor.-Jeff
