Qs back from service-bad news
jmorasch
Car: 91 Q45 x2
went to pick the Q up,the fuel regulator had went out.yhey checked the injectors,was getting fuel,fire,and things checked out they said.there was still a miss though so they did a compression check and #8 cylinder was at 60 pounds? I couldnt believe it...has a bad shudder when the RPMs come down past 15k. dont know what Im going to do???
Raxephon
Car: '04 RX8...for the moment...
jmorasch wrote: ..has a bad shudder when the RPMs come down past 15k. .......
Do you mean 1500rpm?
My new, as of last saturday, '94 Q45 just started having a shudder of its own under 1500rpm today. Except mine has no maintenance history,(as in its never been serviced, not lack of records), .
Mine started just after the tank dropped below half, but hadn't reached the quarter mark on the gauge yet.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Wet or dry compression?
jmorasch
Car: 91 Q45 x2
dry compression test from what I know. I posted ealier after getting home from picking the car up.they had narrowed it to one cylinder.but stopped by advanced auto to talk to a guy I know there that has a Q.had talked to him a few times before and told him about NICO.he came out and we pulled the clips and unplugged the injector,and it made no diffrence or change in the studder.so Im assuming the injector is the real problem. dry compression would give inacurate readings???
Trumpkin
Car: 1995 G50
Did you ohm the injector?
