.lessthanjakejohn wrote:I'm thinking that most road courses have a fair amount of straightaway and so therefore the SR will be able to pull ahead there. The SER spec V has a great suspension set up from what i hear, but its FWD and lacks power.
The stock 240 suspension is soft but in top notch condition it should get the job done.
well the pros for the se-r to me, would be fairly lightweight (about the same as teh 24o), the gearing, the torque for coming out of corners, and as far as straights, id say the se-r could hold its own against a 24o (sr20det), ive heard tho, that sr20det 24o's pullin 14.2 stock, i find that hard to believe, either way, id say itd be closelessthanjakejohn wrote:I'm thinking that most road courses have a fair amount of straightaway and so therefore the SR will be able to pull ahead there. The SER spec V has a great suspension set up from what i hear, but its FWD and lacks power.
nlzmo400r wrote:well the pros for the se-r to me, would be fairly lightweight (about the same as teh 24o), the gearing, the torque for coming out of corners, and as far as straights, id say the se-r could hold its own against a 24o (sr20det), ive heard tho, that sr20det 24o's pullin 14.2 stock, i find that hard to believe, either way, id say itd be close
thats what im sayin, i don think the power difference would be that much, especially comin out of a turnEZcheese15 wrote:I'd say on a very tight course, like an autoX course, the Spec V would have the advantage. However, on a roadcourse, the SR 240sx would.
The spec V's suspension blows away a stock 240's suspsension. And it has much nicer gear ratios for an autoX course than the 240sx.
But on a roadcourse, the 240's power would overtake the spec V's handling. A good spec V driver can take a medeoker SR 240sx on a roadcourse, but if the drivers are equal, the 240 would win.
Also, the 240 is less likely to blow up.
nlzmo400r wrote:yea but still, it should be quicker than a car with 4o less ft lbs of torque, and only 2o more hp, and the weight is the same, and both come with 6speeds (spec v is a lil closer ratio)
