isoteric wrote:why do you say that motor has less overall potential? i'm just curious since it IS the NEW 4-cylinder, not to mention the immediate 15 hp and 20 lb-ft torque gains before any machining, which I was also planning on doing.
newer does not necessarily mean better.
Quote »I'm just curious b.c I'm trying to do as much possible research on this as I can, I would like to stick with the 4-cylinder and I would very much like to stick with the 2.4/2.5 b.c of the displacement.[/quote]right there with you on that one
imo, what's wrong with that engine is that to get 2.5 liters out of it they had to use a very long stroke and comparatively short rods, which is not optimal for an inline four. after searching, i found the stroke is 100mm and the rods are 163mm, making it obvious what the ratio is; people call the KA-D a "truck motor" but in stock '91 configuration (before the gradual detuning process that every nissan seems to go through) it's more capable of power output and RPM than the QR is.
a 1.63:1 rod ratio is great for torque because the quickly-moving piston promotes better cylinder filling at low rpms, which combined with that close-ratio 6-speed makes the new v-spec a good stoplight fighter (read: they usually kept even with my stripped 160hp/2000lb gti)- but i haven't forgotten how my old '91 classics were good for 7500rpm, bone stock; & they still had enough torque that an LSD was very beneficial to them. i personally don't think a QR25 will see 7 1/2 even with a built bottom end- forged internals can only do so much against unfavorable geometry.
dave coleman mentioned fixing this problem by using a QR20 crank available from other nissans in an analysis article on the QR25, but somehow i can't see the cylinder head being THAT much better than SR or KA that i'd go through the extra expense of buying a newer QR just to take it back to two liters...
in short, that big fat displacement number the QR25 has certainly seems attractive, but attaining it required compromises that you simply don't want in a high-performance motor of any kind; a short rod ratio is bad for boost tolerance as well as RPM...
Quote »If I DON'T do the swap, I would be rebuildng, boring, port and polishing, and all the other little N/A goodies I could with the KA, EVENTUALLY going with a fabricated supercharger. At least that's what I would LIKE to do.. buuuuut, like I said, I'm still getting in research and just want to know all I can with everyone's opinion. Thanks.[/quote]i think you've got a good plan; but the few grand it'd cost to get a stock QR25 shoved in there would be better spent executing it on your KA.
