Qestion to all 5 speed S14 zenki owners. . .
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Alright, so my clutch peddle has always felt very soft, almost like you're pressing on a pillow. . . And today I decided to do the infamous clutch damper removal for the purpose of stiffening the peddle. . .
So anyways, after the modification has been performed and bled properly, the clutch peddle didn't really feel all that much different. . .
So my questions are as follows;
1. How's the degree of stiffness on your clutch peddle?? And also include if you have done the damper bypass mod.
2. Is my peddle still somewhat soft due to the fact that my clutch might need to be changed?
And yeah, if you guys might know some extra tricks to stiffen the clutch peddle, please let me know!
Thanks in advance.
crakin
Car: 1996 240sx s14, 2008 Chevrolet silverado crew cab,
2011 Suzuki gsxr 750
mine is a long and slightly resistant press. I've looked into aftermarket or modified clutch cylinders in the past but I cant remember. that may help.
Has anyone ever bled a clutch line before?? may have air in the line?Maybe upgrading to steel braided lines, that may be noticeable?get a chilton or haynes to see how to change clutch fluid and bleed out the air.
good luck
Dazzla
Its not a big issue to me. Its just I've noticed it feels softer the faster I'm going. It feels alot softer if I'm accelerating fast and shifting in higher rpms.
n00b240
Car: '03 6MT
I dont know if I would say its like pushing on a pillow. My clutch is quite soft in the 240. Last year for about 4 months I had the privilege of driving a 6 speed G35 coupe. I came back to the 240, and nearly ripped a hole in the bottom of the car from pushing on the clutch so hard, my foot hurt for a good day
I agree with crackin, that Ive got a long and slightly resistant press on first push, after the release point, its hella soft. But its never been an issue. Try a honda FIT, those things are like pushing on air. Im sure your clutch is fine
Jagstang
Alright thanks a lot guys, but too bad... I hate the feeling. My brothers Nissan NX 1600 is as stiff as a rock, and I love that feeling. Also, my buddies S13 (with the damper removal mod) feels so much stiffer. . . When I test drove his S13, I stalled it the first time because it was just. . . So much different. . .
WTF S14's SUCK!! (In the clutch peddle softness area).
Razi
Car: Moo
Get a stiffer pressure plate, that'll give you a stiffer clutch pedal feel.
kouki munster
Car: 97 base 240
Replace your clutch with one that has a stiffer pressure plate, problem solved. Edit: damn Razi beat me to it
The biggest advantage to ditching the damper it that it is now a crap ton easier to bleed the clutch, and the only time that removing the damper box will do any good is if it has some air in it from the last time someone changed the master/slave cylinder, and didn't bleed all the air out of the system.
FusionR300zx
Car: 1993 300zx/1997 240sx
if you can read this you really need to get laid.
kouki munster
Car: 97 base 240
FusionR300zx wrote:if you can read this you really need to get laid.
Random post is very random.
Hoffman5982
Car: '95 sr20det 240sx
I had to drive a friends 5 speed protoge home when he bought it(never drove a stick) and his had literally no resistance. I kind of liked it, but I don't know if I'd want to drive that everyday. my 240's clutch has some resistance but I can also tell when it's engaging which is nice. I haven't removed the dampener, but I haven't gotten under there to see if the previous owner did. He would have told me if he did though
crakin
I took one of the new hyundai genesis coupes 2.0T for a spin and that clutch is the best i have felt in my run through of various cars.
DMan II-40
Car: 1995 240SX SE
You mean: 1f y0u c4n r34d 7h1s y0u r34lly n33d 70 g37 l41d?
artman540
Car: 1998 Nissan 240sx
I would check the slave and clutch master cylinders. I had a bad slave and had a super soft pedal, when I replaced it pedal was stiff as Hugh Hefner.
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
Yeah, if your clutch is still soft, you either have air in your system and/or your pressure plate is worn.
I have an RPS MAX pressure plate, everytime I feel a stock 240 clutch i'm afraid of punching it through the floor, lol.
Jagstang
artman540 wrote:I would check the slave and clutch master cylinders. I had a bad slave and had a super soft pedal, when I replaced it pedal was stiff as Hugh Hefner.
I think my clutch peddle's current stiffness is already ON the Hugh Hefner stage (old, worn out, and soggy).
str33tprintz
Car: 1996 Nissan 240sx SE
Yeah my clutch is super soft as well. But I get stuck in five o clock traffic everyday on I95 so I don't mind it so much. I had to drive a friends turbo Focus with a stage 4 clutch for a while and stalled it more times than I would like to admit but I definitely enjoyed knowing when the clutch was engaging. After going back to my 240 I was kinda disappointed.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
Jagstang wrote:peddle
PEDAL
Jagstang wrote:My brothers Nissan NX 1600 is as stiff as a rock
cable clutch. i went through the same thing when i went from my first s13 to a b14, then back to an s13.
