gjvr22 »
https://forums.nicoclub.com/gjvr22-u173403.html
Sat May 21, 2022 11:09 am
Quick update;
If you only replace the control valve body, that unit is mounted INSIDE the transmission housing and would therefore have to be drained and opened.
I have no confidence in a "used" uninstalled valve body. I cannot imagine you can get a reputably rebuilt one for less than $1,000 if Infiniti is charging $1,500. I also have no desire to open up my transmission housing.
I found a used transmission from a dismantler with 40K miles on it and got it for $1,500 w/free shipping and warranty.
If the dealer wanted $2,000 to install, plus a "new" $1,700 valve body($3,700) in my old 180,000 mile transmission, what would happen if my worn transmission goes bad next week? I could be looking at another huge repair bill!
If the used tranny checks out and the install goes well, I should be set in the transmission department for the next 150,000 miles for approximately $2,500.
I think I have made the smartest, least expensive decision and will have my old transmission that I will probably have rebuilt.
Let me know your thoughts if you're interested.
