Q70 2017 Infotainment Center Malfunction
garethm56
Car: 2012 Nissan Fuga Hybrid Y51 VIP
VStar650CL wrote:
Wed Nov 27, 2024 6:09 am
You're most welcome. Posting the full details as you did is always the best way to pay it forward, so once again, great job! :)
Hi VStar, I know you are an expert on this area. I got my VCX SC module: https://www.vxdiagshop.com/wholesale/vx ... VkjTKRuFUa
I have installed the consult program and everything works fine. I have to however initialize system via car menu then reprogram via consult is that correct?
If so where do i buy the subscription to reprogram? is it this one? -https://www.nissan-techinfo.com/dept.aspx?dept_id=25
Any help would be greatly appreciated. Thank you
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
I'm not the right guy to ask, I use the genuine Consult3+ at the shop and I'm no expert on aftermarket substitutes. I can tell you that you won't be "reprogramming" the AV in the sense of reflashing the operating code. What it needs is reconfiguration, the stored values which tell it whether it has a Bose, TPMS, etc. On newer AV's the unit gives you a message saying "Factory Mode" which tells you the configs are missing, but on older stuff the units just go "duh" like yours is doing. If it helps, on a C3+ you go to Reprogramming/Configuration -> Multi AV -> Configuration -> After ECU Replacement -> Manual Configuration, then you get a menu of the configurable items. You set them correctly for the car's options, then load them to the AV.
