Q50 Rear Diffuser & rear sequential signals
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
wiliam the first
Car: 2014 Infiniti Q50 S 3.5H SPORT AWD
Regard the installation of both at the same time. does anyone have experience of doing these installs, max time they should take, if done at the same time of course.?? :gotme
Guessing tops 3 to 4 hrs in a garage with lifts, bla,bla and all the gear
Sounds about right, but that's all dependent on your proficiency with tools and knowledge of the car.
wiliam the first
AZhitman wrote:
Tue Oct 07, 2025 8:18 pm
your right..
I had it all done the by a pro, price 80$ no compaints here, lol. only thing it needs to be done is go back, for the top ends of the diffuser which as always had problems sticking to the body at the corners,about 3 mm off where it should be, so we are going to put some back small nuts and bolts, 1 each side to pull them corners back in.
Return to “Infiniti Q50 / Q60 Forum”
