(Q50) any negatives with a 245/70/16 vs the OE 255/65/16???
K03sport
Car: 04 Pathfinder. My first Nissan was a '72 Datsun 510 Wagon.
Hi. It's been a long while since visiting and posting here, but I've got a question. For all of you 2000s (2004 specifically) Q50 platform owners, are there any negatives in going with a 245/70/16 tire vs the OE spec 255/65/16 ? Rubbing? Handling? Noise? Overall driveability?
Moving down a size the tire options open up tremendously, not to mention the the same tire, e.g. Michelin LTX MS2, drops in price by 10-15%.
Using various tire calculators, the 245/70 has a .3" taller sidewall, a 1.4" larger circumference, 10 less revs per mile (684 vs 694), all culminating to a 1.6% difference overall.
I'm not sure how man yother vehicles use the 255/65/16 tire, but it isn't many and it may be relatively exclusive to this range of Nissan/Inifiniti vehicles, but I can't be 100% certain on that.
I searched and couldn't fine too much on the 245/70/16. Oh, the truck also sees 99% highway/surface street use, but it can find a dirt path when it needs to.
TIA
Hawairish
Car: 2004 Nissan Pathfinder SE 4WD
It'd be a negligible change (29.1" vs 29.5", assuming calculated diameter...actual diameter actually varies and is usually less than calculated). Just be sure to observe any load or speed ratings for the tire.
302LVR
Car: 02' Pathfinder SE, 89' Mustang LX 5.0
I purchased my 02' in 05' and it came with 245/70 Generals installed. They lasted around 70-75k miles or 4.5 years since i mostly did highway driving as well. The tires performed fine with no rubbing or anything and rolled very smooth on the highway. Hope that helps. I'm currently running a 245/55/18 now on mine but i sized it up to my 245/70s and they are about same height and diameter respectively. Hope this helps.
