Q45tech Throttle Position Sensor question.
Need4Speed
Car: Unique Cars, Sailing, Shooting sports
Dennis, I have been going thru all transmission diagnosis procedures to check my transmission out thoroughly and I may have a found a problem.
Under Electrical Components Inspection, AT-67, My Throttle Position Sensor is only showing 3.04v at full pedal depresion. FSM states approx. 4.0v at full pedal depression. Is mine within range or do I ned to investigate further.
-Andy
Q45tech
Closed should be 0.4-0.45 voltsWot should be at least 4.0 volts ~~ 4.4 volts is nicer.Seem to remember the ecu needs at least 3.8 volts to reconize WOT.
As read on the Consult
Need4Speed
Could this TPS problem be part of my transmission not shifting to 3 or 4 manually or in D?
-Andy
Need4Speed
BTW, so far everythig else eletrically related to the AT is checking out OK. Inhibitor Switch circuts are OK so far....I have to check the actual Inhibitor switch itself yet.
What is the posibility of a Shift Solenoid A or B failure causing the problem....and how hard are these solenoids to get to.
-Andy
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
This may be totally obvious, but you can adjust your TPS. Look at the set screws on it & adjust it until the voltage reads within spec.
Mine has yet to be done, along with a CAS dial in, but my MAF is already regrounded & it alone made a huge difference.
Yes, solenoids can fail.
Need4Speed
Hmmmm.....I forgot about that....thanks for the reminder!
Still trying (hoping is more like it) that I can pin my transmission problems on some cheaper electrical AT component rather than a total R&R! :(
-Andy
Q451990
Has the TPS been adjusted in the past? If not, I wouldn't think adjustment would be necessary. They seem to be fairly bulletproof...
Heath
Need4Speed
I have not adjusted it....someone in the past 182k could have though....
-Andy
Q45tech
Well if you are measuring correctly it [TPS] is set wrong. First things first get the sensor corrrect via the Consult........then worry about transmission internals.
TPS can develop wear spots but usually at cruise voltage.
Need4Speed
Thanks, Dennis. :)
Now I have to see if I can find a dealer closer than 150 miles that has a Consult......
-Andy
Q45tech
The closest Nissan dealer is 150 miles away?
Need4Speed
I was speaking of the closest Infiniti dealer, there is a Nissan dealer in town....Just not sure if I want to go back there........... :mad:
Past expeince there has been way less than great. But I suppose I could suck-it-up for a consult diagnosis.....
-Andy
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Dennis, cant you just read the voltage with a VOM on the car.....?? I mgiht wanna try that (more free stuff)
HeavyDuty
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
DCB response:
Yes.
Q45tech
The voltage feeds an A to D in the ecu so I like to see what the ecu actual thinks the sensor is reading.
You could ASSUME that the output [of TPS] voltage is translated correctly.VOM vary in accuracy and operator knowledge.........what counts is what the ecu says it sees.
