motorbobb wrote:I just got my 94Qt serviced. One of the pieces of work was replacing the valve cover gaskets. The infiniti quoted charge is ------ $1150! I have not changed a valve cover gasket in 20 years since last working on my 69 z28 but that was a 45 min job. The infiniti shop schedule calls for 10hrs for a valve cover gasket replacement. As a complement to Roswell infiniti, they did knock several hours off the scheduled labor as I needed $3000 worth of work.
Q45tech: You work at t3 in Atlanta? I live in ATL. A few years ago, a guy walked up to me in the work parking lot as I was I was getting out of my 94Qt and handed me a T3 card. He said he recommended the service.
My problem: I am trying to figure out if there is anything that can be done to breath life back into the performance of my car. The car just does not accelerate like it used to a few years ago. Over the years, I have had all the normal induction parts cleaning done, and during the recent service had the plugs replaced. The car doesn't miss or display any obvious characteristics but it just is so flat / unresponsive, particularly at low rpm's. If the engine was an old, pre-computer / electronics / vtec motor, I would be playing with the spark advance.
My car is a Q94t, with 125k gentle, well maintained miles. I am not looking to add any aftermarket performance, just trying to restore performance close to OEM. Is there any obvious thing I should have someone look at (ie are there any adjustments to valve or spark timing) or is this just normal old age performance? (or maybe the fact that my performance benchmark is warped since my daily driver is an E55?).
Any advice from the board would be appreciated. rgds motorbobb
Dennis with 270k on his 90 Q still experiences as new performance (or at least very close), as do I and many others...
Just speculating, id say your knock sensors are bad.... This is all pretty easy stuff... if you took the car into T3 for an hours worth of diagnosis, they will tell you whats happening
