But I had aluminum heads on my last two big blocks, L-89 and L-88maxnix wrote:Torquing in to iron (big block Cheby) is a lot different than aluminum.
The elasticity fails, hence they need to be replaced every 60K- 80K.
Don't know if the gasket material was chnged on the VK, but I suspect not.
I am religious about my fluid changes/flushes, but am trapped into using the dealer. I know of no good reliable and knowledgable indepedent shops in Phoenix that are familiar with Infiniti. The dealer quoted me $1300 (!!!!) to replace ONE valve cover gasket!!!!! I believe the interval for olugs on F50 is now up to 90k. When I have that done, I'll try to get a break on valve cover gaskets then too.Q45tech wrote:They usually last a little longer than 70k say 100k depending on driving suitations and local ambient and oil composition and the 90 day change interval.
We change both valve covers and throw in labor for new spark plugs for $575 or $650 with Active or TCS [extra labor required] adds parts costs.
We have things apart so we recommend a few other services [fuel filter, air and oil change all fluids, clean plenum and TB/injectors/EGR.
You cannot own an old Q cost effectively if you must pay $120per hour dealer labor and do all the necessary things to maintain as brand new.
I remember 12 years ago when we started at $45 per hour now at $85 dealers were at $65 now $120.
Greg does. AZHitman.StarPD wrote: I know of no good reliable and knowledgable indepedent shops in Phoenix that are familiar with Infiniti.
Once again though, are the valve cover fasteners acceible, and will snugging them extend the time interval to change them?
I'll look him up.Thanks.maxnix wrote:Greg does. AZHitman.
Well, you missed my implication on the aluminum head. One torque on new rubber cushioned washers is all you get, without penalty of stripping out the thread receptaclet.
Last person I want to work on my car.capncash wrote: any half *** mechanic should be able to do this for half that price.
Damn, my dealer's only $86 an hour. But then again we're not an Infiniti's dealer...but we do sell Lincoln's. And we charge the same labor for them as we do the Mercury's and Mazda's. I guess I'm working on the wrong cars?Q45tech wrote:I remember 12 years ago when we started at $45 per hour now at $85 dealers were at $65 now $120.
Typically, anytime you are considering bending something, or hitting it with a hammer, it is the wrong procedure. But, without having done it myself I can't say for sure. However, I will have that pleasure soon enough as my valve covers are leaking too.capncash wrote:So before I go gorilla on this tube. Is this the correct procedure? Just bend the tube up with a ratchet extension?
