Why isn't the crank in the oil? I would think that it would best. for lubrication purposes, to have the crank going through the oil.Q45tech wrote:Daily driver assumes low average rpms plus the Q has a deep pan and the crank isn't in the oil. Nor are the crank weights. At 7,000 rpm there isn't much oil in the pan in any event.
Shving the crank does not reduce duribility much. One of my friends had this done to his 1994 mustabg 5.0. It has survived 6 years so far. I think that seems reliable.Q45tech wrote:Racers may not care about durability [shaving the crank].
Drag and frothing of the oil. Seems rather obvious, no?PoorManQ45 wrote:Why isn't the crank in the oil? I would think that it would best. for lubrication purposes, to have the crank going through the oil.
Look, I made another dumb comment!
Hmmm......might explain why firing ACP .45 rounds into the crank ain't doing it.Q45tech wrote:The only viable way to rebalance the crank after knife edging is to use heavy metal [tunsten] inserts or depleted uranium plugs.http://www.circletrack.com/techarticles/84199/
http://victorylibrary.com/mopar/crank-bal-c.htm
maxnix wrote:Hmmm......might explain why firing ACP .45 rounds into the crank ain't doing it.
