mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Thu Sep 10, 2009 7:18 am
Have you tried the home made consult in which you connect your laptop to the earlier G50 models using the ECUTalk cable? I have the ECUTalk cable and I'm using the newest version of OBDScantech. When I was doing the power balance test, I thought that it worked by shutting off the injectors like the original consult I and II , but after I posted a question about the feature that you can shut off multiple cylinders at a time, I was informed by another member of NICO that the software doesn't shut off the injector but rather the spark instead. So, I decided to see for myself and I picked one of the front injectors that I could get to and unplug it. I then got my volt meter and probed the 2 terminals while I had the engine running and had that particular cylinder disabled by the software, I noticed that there was no change, I was still getting current and ground to the connector.
