Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Tue Aug 17, 2004 5:28 am
The inserts on the non t model slip in the strut housing whereas the T car requires replacement of the whole assembly with a new design upgraded part.
Guess you could find a wreck and get the spings top, seats etc and then put new inserts in the junk assembly.
Didn't budget for shocks, every used car needs something, that $2,000 you hold in reservefor 97-01.
We have been getting a rash of LX470 with trashed load/height adjusting systems...........need recharged accumulators and leaking shocks..........the Q45 active all over again.
Takes 6 hours each to change a rear shock plus the shock ~~ $1,000 per wheel..........no substituting without replacing springs everything.........couldn't have happened to a nicer brand.
