texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Fri Apr 13, 2007 3:18 pm
This reminds me of a long standing issue my wife once had with her Lincoln Town car (1984). It had throttle body fuel injection, Ford Duraspark (electronically set ignition timing, non adjustable distributor). Every so often (no particular interval) it would not fire. tow in to Dealer--invariably started on the tow truck bed and drove down. Was not reproducible. They kept changing stuff all through the warranty-but never cured it. continued changing stuff(at her expense) after. Then I came into her life and that crap stopped. When it refused to start. Wait an hour, or day. Then found if disconnected battery, worked every time. Then went to Caracas (Venezuela) and met a man (in the parking garage for the main theater there) whose same vintage LTD would not start. I helped him check things--first took off fuel line-good fuel pressure-then he immediately removed battery cables, reversed them for a split second, reconnected them -and bingo!!. He said it was a 'well known defect in the Dura spark computer code' and it would freeze-up sometimes and not fire up on start. Reseting it worked always.
First thing I always do when electronics don't work right is check connectors, then de-power completely.
