That is good news I would really like to get this riding a little better while I focus on restoring the rest.maxnix wrote:4 main are about 85% of the ride and should identify malfunctioning actuators, which Keith also has on occasion.
What was your workaround? What will bring it closer to 100%?3Q Jay wrote:on my silver 94, i did all 9 at once. it was dead as a rock before that. when the system came back to life i had problems with the multivalve unit. still have a few burping groaning issues, which i've done a workaround at Keith's recommendation. so, that one is like a 90%.
Are your wheels too heavy or is it something else?3Q Jay wrote:it's also on 18's, which apparently isn't a real good match for the active control.
Did the PO have them done by Keith?When your car goes into safe mode, what exactly happens?3Q Jay wrote:on my recently acquired 95 black, the PO did the 4 strut accums about 2 months before i bought her. according to PO, made 'night and day' difference. my immediate impression after driving silver was that black was 'rough', considering it's on the pillows of 215/65/15. black also goes into fail-safe mode very frequently.
Dust boots will have to be replaced for sure.How necessary is it to replace the bumper bounds if the actuators are leaking?3Q Jay wrote:some of your pics are a bit blurry, but i didn't see obvious leaking of your actuators (struts). you will definitely want to replace the rubber boots and bumper bounds (they are separate on the active cars). as long as the actuators are not leaking, you should be good to keep those.
1. In deference to Keith and his intellectual property, I'll just say we reduced the system gain.lino wrote:
1.What was your workaround? 2.What will bring it closer to 100%?
3.Are your wheels too heavy or is it something else?
4.Did the PO have them done by Keith?5.When your car goes into safe mode, what exactly happens?
Dust boots will have to be replaced for sure.6.How necessary is it to replace the bumper bounds if the actuators are leaking?
I tried adding some MMO.3Q Jay wrote:1. In deference to Keith and his intellectual property, I'll just say we reduced the system gain.
How can you tell if you buy another MV if it's good or bad?3Q Jay wrote:2. Prolly changing the MV yet again.
I get the clunking and groaning. I'm waiting to see what happens when my actuators are fixed. Maybe the groaning will go away as the MV is probably working harder always trying to deal with the actuators instability.3Q Jay wrote:5. there is a clunk from the MV area, the car rapidly changes attitude (RR seems to drop, havent actually measured it), and the actsus lite comes on.the infuriating thing is that i always get code 55 on the self diagnosis. i thought i got smart yesterday and did the self test, then started the car and drove while still in self test mode. it showed 55 up to the point of the 'clunk' and then just went steady actsus ON.
Have you changed the bump stops on your car before? If so what was the condition of the original ones?3Q Jay wrote:6. i should have been more precise. change the boots. change the bumpstops. keep the actuators unless leaking.
