I encourage you to read this article fully, if you want a full understanding of the active suspension
http://www.autosite.com/garage...e.asp
I will give you some brief highlights
The active suspension Q45 is the best handling Q45 if it is in proper shape. It is also soaks up bumps (rides nicest) of any Q45.. remember this is only if it is good condition. If the actuators are flat, it can be downright nasty..
The A will allow no roll under cornering up to .5g It then will allow a small amount of roll to let the driver know he is approaching tire adhesion
The car will not dive under any sort of braking.. no matter how extreme
The car will not squat under accelration.. no matter how hard you floor it..
Active suspensions are superior.. Look at this thread. http://www.nissaninfiniticlub....64848
It shows an active equiped toyota on the track, vs a non active toyota.. The difference speaks for it's self..
The active suspension wasn't understood here. Critics faulted it because the normal Q handled so well, under normal driving it's hard to tell the difference.. Well if you only drive 65 and in a straight line, and not very aggressive, the benefits are probably offset by the eventual maintenance costs..
I fully plan on exploring the limits of the active suspension on the track.. I believe on the track/high speed driving is really where this suspension shines..
It was co developed by lotus.. Lotus is the grandfather of all active suspensions
Active suspensions were so dominant in F1, they were immediately banned..
If you can stomach the repair costs to get the system fully working properly, I encourage you to pick one up. The system has only been replicated (and probably advanced) by Mercedes Benz.. They only put it on their most expensive/top of the line AMG/reg models.. Its not even an option.. there is no option. There is just the active suspension..
Only about 20% of the Qs sold here, were Actives.. In Japan 80% sold were Actives..
If you want to experience one of the automobile industries most advanced suspensions ever (still) get an A..
