Q45a ECU questions
cplus
does the Q45a runs the same ECU as the non-a's, will I be able to usestandard Q45's or aftermarket ECU in the active Q45?
what's the wire for in the first pic, the black one at the bottom, it runs all the way to the passenger compartment with 2 male connectors?
also can i connect directly to the ECU without the extension?
thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the active ECU software is different but the hardware is the same. so if you were to get a NICO ECU you just say you have an active car and we can load the active software on no problem....
if you ran a non active ECU on your active car itd probably throw an active suspension code, but it may not....
the wires your talking about in the first pic definitely arent factory. i wonder if you have some sort of active suspension controller.... i bet those 2 connectors are for the control unit on the suspension controller
might take the box that the wires are connecting to and see what it says.... my guess is it wont say NISSAN on it.
cplus
elwesso wrote:the wires your talking about in the first pic definitely arent factory. i wonder if you have some sort of active suspension controller.... i bet those 2 connectors are for the control unit on the suspension controller
the box with a "D" on it in the pic has the following numbers:52700 8(or 6, can't see it clearly)4010 1514no NISSAN on it.
and on the huge blue conecctor of the extension wires has a lable:FIELD DHC-11H
the 2 connectors were connected to somthing, but the control unit was gone.
it might be a suspension controller, cause only left side ofthe car will lowered when engine start, it will drop about2 inch, but right side wont change at all, I had a tech tochecked the car, but he couldn't find anything wrong with it.
cplus
you are right, it's a aftermarket air sus controllerインフィニティQ45 HG50(H1.10~H9.9) DHC-11Hi tracked down to herehttp://www.field-net.co.jp/lin....html
Modified by cplus at 3:51 PM 10/1/2006
elwesso
2007 BMW M Coupe
now you just have to get a controller thing....
cplus
elwesso wrote:now you just have to get a controller thing....
it's gonna be hard to get , even if I get one, is it gonna work . since we know it's aftermarket conntroller, can I just connect directly to theECU, without the extension wires?
found one on yahoo jp, but wont ship internationally
Modified by cplus at 4:37 PM 10/1/2006
elwesso
2007 BMW M Coupe
theres companies out there that will buy stuff and send it ot the US. One is called like Rinkya or something like that.... i know i posted info about it a while ago.
cplus
elwesso wrote:the active ECU software is different but the hardware is the same. so if you were to get a NICO ECU you just say you have an active car and we can load the active software on no problem....
where can I purchase the NICO ECU
