Q45a Cooler for Oil Cooler?
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I noticed on a wrecked 1994 Q45a that under the driver's front fender is a little cooler with an electric fan attached. I was thinking that this would be an awesome atf cooler! It has all the mounting brackets, an electric fan, and a small cooler. Do any of you guys with experience with oil coolers on Qs or this Q45a cooler have any insight?
Thanks ahead of time.
Modified by AlabamaDan at 9:54 PM 6/4/2009
qship96
Car: 1996 Infiniti Q45
Would make for an ideal transmission fluid cooler- as the extra heat is not dumped into radiator, and the fan allows greater efficiency at idle when airflow is minimal at rest in the fenderwell- GRAB IT
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Makes a great ATF cooler. Not sure how fan is switched.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
i would think you might want something a little heartier for an oil cooler.. oil runs at pretty high pressure, not sure how it compares to a transmission cooler or similarly the active suspension but i bet its less (on the active/transmission)...
Skibane
Car: 2000 Q45 AE 110K
How quickly could motor oil flow through it, without creating much backpressure?
Is it more restrictive than an off-the-shelf engine oil cooler?
If so, it might do more harm than good - particularly when the oil is cold and thick.
Mint Q45A
Car: 1994 Q45A
I need the "multivalve" that goes right after/next to the cooler you described, towards the wheel well. Is this still available on the car you saw?
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
maxnix wrote:Makes a great ATF cooler. Not sure how fan is switched.
fan is switched by: temp sensor in active reservoir, active ECU comparitor, ubiquitous -89981 relay.
Mint Q45A
Car: 1994 Q45A
Hi Jay,Where is the relay you mention located in the car? Tks.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
aft of the LF strut tower. kinda under the fender, but still fairly accessible.
Mint Q45A
Car: 1994 Q45A
Tks!
AlabamaDan
1998 Infiniti QX4
I meant ATF cooler, not oil.
How should I wire up the fan? Any suggestions?
